Why does Rad...
Cory
Why does Rad...
Post by Cory »
...put ball bearings in his bowls when he takes top down pictures?
Government secrets lie in the bottoms of his bowls?
Massis
Re: Why does Rad...
Post by Massis »
because it keeps the pipe balanced and upright?
Re: Why does Rad...
Its a magnet and attracts to a magnet on the base. Helps hold the pipe in any position for photography. Many pipe makers use one.
Massis
Re: Why does Rad...
Post by Massis »
caskwith wrote:Its a magnet and attracts to a magnet on the base. Helps hold the pipe in any position for photography. Many pipe makers use one.
I'm actually in the middle of building a cabinet this way. Each shelf has 5 20mm diameter magnetic discs, 2mm thick, sunk into the wood. They have a pulling force of well over 1kg each.
And I have a bunch of 8mm magnetic spheres to put into the chamber, so I can store my pipes in a nice display kind of way.
Cory
Re: Why does Rad...
Post by Cory »
Gotcha. Makes sense - thanks!
Re: Why does Rad...
I just assumed it was to hide the bad drilling.... :mrgreen:
