First ever pipe....what tools are a must?
I am getting ready to make my first pipe ever...could someone look at my list of tools and tell me if I need any hand shaping tools. I can not afford a lathe at this point. Here is a list of my tools:
drill press
band saw
router with table
table saw
What bits, files...etc...should I buy first?
drill press
band saw
router with table
table saw
- achduliebe
I would throw in a decent rasp, a file and a chainsaw file. I actually have a Nicholson file/rasp combo that has a flat file and a flat rasp. It also has a concaved rasp and a concaved file. I also have just a regular old file, like you would use to sharpen a lawn mower blade. A chainsaw sharpening file and a 1/4" prism shaped file. All of which I beleive I picked up at Lowes. I actually think all, except for the chainsaw file, were in a combo pack together.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
A German Shorthair!! Wow...gorgeous avatar pic. German Shorthairs are my favorite breed.
You'll also need sand paper at 220, 400, 600 grits, and some buffing wheels and buffing compounds. You can use your drill press to buff.
Spade bits that you grind to an appropriate profile. If you don't want to grind them yourself, you can buy them from Pimo or inquire in the "Buy, Sell, Trade" section of this forum. Someone here might sell you some.flea1 wrote:What types of bits will I need for the tobacco chamber?
- achduliebe
As for the combo file/rasp and my other files. I think I maybe spent around $15 for all of them at Lowe's.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
I just thought about the fact that you apparently intend to drill your first pipe yourself. With that in mind, another key tool is something to turn the tenon for the stem. A Pimo tenon turning tool is the least expensive route, and a metal lathe the most expensive.
Do a search on leather dyes for stains. As for buffing, you need buffing wheels that you can mount in on a motor (or in your drill press).
- achduliebe
Another little hint to start out cheap. I got some cheap buffing wheels from Harbor Freight Tools. There were, I beleive, 3 wheels in one pack and I think they came with an arbor and some buffing compound. I used the buffs but did not use the compounds, I got those from PIMO. The wheels were a bit small, but they will do for starting out. I think they are like 4" wheels. I mounted the wheel that I was going to use on the arbor and chucked it up in my hand drill (that was before I had a drill press). It did an ok job.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
- achduliebe
I would think that you could mount any of them on an arbor and chuck them up in the drill press. The only catch is that your buffs will be oriented horizontally instead of vertically. That is the way that I plan on buffing my next pipe. That is unless I get a grinder between now and then.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
- achduliebe
You could definately do that....just tell her not to juice it too much or she might end up flinging your stummel into your neighbors yard!
-Bryan
www.quinnpipes.com
www.quinnpipes.com
Oh boy... 8Oflea1 wrote:THAT IS TOO FUNNY!
So when you guys finish the final product...I've heard some people rub honey in the tobacco chamber. What do you guys do?
...this is quite the can of worms.
Do a search on "bowl coating".
