New to pipe making but heres a few I have made
Here are a few pipes that I have made. I just started making pipes this year just because I wanted to see if I could. Thank you in advance for your feedback. Most of my pipes are all hand shaped. I just started making my own stems or modifying the premolded stems I have purchased.
Re: New to pipe making but heres a few I have made
These look like first pipes. Next thing I would suggest is opening up the slot down about 2 inches into the stem. That's going to help a lot with smoking quality. You can either use a pottery saw or a jigsaw blade to funnel the airway. Once you have a good slot, figure out how to get the bite zone behind the button down to about 4mm thick or less. Takes some practice and usually some sanding through the airways before you get it right, but the comfortability is worth it.
2" slot? That's the length of many of my stems!
Personally, I just try to make sure that the airway flares towards the button starting about an inch in at the furthest. Get rid of internal ridges and make sure when you draw through the stem there's no whistle. If you can get a deep air tunnel sound you've nailed it.
Yeah.....I go between an inch to an inch and a half, depending on the design of the stem. If it is a straight taper an inch is safe. If it is going to be a super thin saddle I stay around 1.5" deep on the funnel. Cuts down on the fear or sanding through the airway. However, I only started doing that once I got comfortable cutting the funnel dead center of the stem and not letting it creap high/low. No matter how deep if it isn't centered you're gonna find it with files or sandpaper.
But, If you're like David and 99% of your pipes are 3" overall in length an inch is probably safe.
Lol! Scottie has spoken the truth!scotties22 wrote:But, If you're like David and 99% of your pipes are 3" overall in length an inch is probably safe.
The majority of the bits behind the button on my stems have been at or under 3mm and I usually stop my taper bit at 1/2" before the end of the stem. Not necessarily saying to aim for that though. As Ernie has said, "The pucker factor on that is extreme."
Like Scottie, I usually cut my slot 1" to 1.5" deep. On occassion, with longer, thin saddles, I'll go as deep as 2". When I first started in 2008, I recall the experienced guys advise at least 3/4" deep so I've never cut it less than that.
- baweaverpipes
- The Awesomer
Mr. Huber, you're right..........2"..........that's mighty deep.d.huber wrote:2" slot? That's the length of many of my stems!
As David pointed out, the exact measurement of the funnel is less important than the fact that it's a consistent draw. JT Cooke actually cut stems I. Half to measure out what a consistent airflow felt like.
Thank you all for the comments and feedback. I obviously was winging this stem since it was my first one that I have made. I appreciate you all taking the time to give me some information like you have.
