Theme/shape up for vote
Poll ended at Fri Feb 28, 2020 9:42 am
Blueprint shape (design to be classic shape)
11
21%
Billiard
3
6%
Bulldog/Rhodesian
15
28%
Creature
4%
Dublin
9
17%
Horn
3
6%
Eskimo
3
6%
Prince
7
13%
Total votes: 53
Here's my entry!
(391.68 KiB) Downloaded 2 times
Adui
Post by Adui »
Nice pipe!
You guys are making me second guess my entry.. I know I can do better, NOW.. but it really was my best work when I made it. I've only made one better and that was an Author
Doug535
Post by Doug535 »
A couple of firsts in this one for me, first Bulldog and first diamond taper stem, it's also a military mount (not my first time).
https://imgur.com/a/FvaluSY
Blackbeltpipes
Post by Blackbeltpipes »
Here’s my first PITH entry... I have a little bit of light scratch work to buff out but it’s complete for the most part... hoping the recipient likes it as much as I do! Am I the only pipe maker that wants to keep every pipe they make...? I have a hard time letting them go!Image
mikecouch
Post by mikecouch »
Fellas, my PITH pipe is nearing completion, but I need a few more days to get it finished. It’s shaped, the stem is profiled, everything is glued up and ready for finish work. Crazy work schedule this week, so no time in the shop.
Terrible photos, but it's finished:
Just need to stamp it and give a final buff.
Thanks to Premal for setting this up and giving us all a chance to stretch our legs! I did play it a little safe with the shape, but I used this an opportunity to try some new tools and techniques - which hopefully will make it into the video I shot of this build.
OK, I decided to enter at the last minute.
Tossed this together this morning from some odd pieces-parts I had lying around.
Is it a "bulldog"? Depends on how hard you squint and how many beers you've had, but I say yes, and my cat agrees.
I dunno, George.....we know you're making actual pipes these days. Seems you're about due to enter for real.
Just sayin'
inicol
Post by inicol »
Done!ImageImageImage
Sent from my SM-G975U using Tapatalk
20 years old, eh?
Someone has talent AND been paying attention. :D
Fortitudepipeco
Post by Fortitudepipeco »
I’m going to have to pull out of the pith this year. I’m a brand new pipe maker and I just didn’t execute the pipe I had planned very well. I’m going to keep working to get better and comeback next year. There are some really beautiful pipes this year and I will definitely be using them for inspiration.
inicol
Post by inicol »
LatakiaLover wrote:20 years old, eh?
Thank you. That means a lot coming from you!
Folks, due to circumstances and bone laziness, I may need another day or so to finish. I will guarantee a pipe to my recipient but may be a day to two late.
I do have a back up that is sort of Rhodesian-ish, so if the deadline is hard, that one goes.
The only arguable error is the floor of the bowl probably being too thin. .25" is the minimum regardless of pipe size (it's a briar thing).
Also, with this sort of design, tilting the chamber radically to avoid the problem only trades it for a different one: Charring of the chamber wall on the shank side above the drafthole.
In short, if you make another of these try adding a little beef through the heel.
Before anyone gets riled up: I know Bo Nordh invented the shape and etc. I also know what comes across my bench.
PS --- If you've measured and it's .25"+, and the chamber isn't whacky angled, then never mind. The pipe will only give a short smoke, but that's OK. Form must follow function, not the other way around.
Hello friends! A few makers are finishing up their pipes and I’m waiting to hear from a couple. We are going to hold the drawing Sunday afternoon at about 5pm eastern USA time. I will do a live ig post on @chhedapipes for the drawing. I will update the list with those that are completed and near completion. Those that have dropped out or I have not heard from will be removed from the list. Thank you for participating in this year’s pith!
Thanks again for organizing, Premal!
A big turnout this year....
n80
Post by n80 »
Agree with George. That is a tough pipe to make with adequate floor thickness. Have tried and failed several times. Seems like the Giegers have some sort of trick with their Bodog pipes, named after Nordh of course. Can’t remember what they do but I think it has to do with a cone shaped chamber and possibly an angle to the chamber as well.
W.Heisenberg
Post by W.Heisenberg »
Thanks for putting the PITH on again this year Premal! This's the first year i've been able to participate, and have learned a LOT by just watching this thread. Next year, perhaps we'll pull out the stops and be a bit more "adventurous".
W.Heisenberg wrote: Fri Jul 31, 2020 9:29 pm Thanks for putting the PITH on again this year Premal! This's the first year i've been able to participate, and have learned a LOT by just watching this thread. Next year, perhaps we'll pull out the stops and be a bit more "adventurous".
I think a bulldog was just about the limit of my adventurousness, thank you very much. The diamond shank was a challenge, and had it not been acceptable to forego the accent ring for us non lathe types, I would have been screwed. :)
Plan B I should be finished the one that I am working on by Sunday. If I do, my recipient gets his choice.
