Precarbonizing a bowl
BlueBriar
Post by BlueBriar »
Hey guys, so iv always believed in the past that a chamber that was not pre-carbonized required more work to break in, but smoked better long term due to the tobacco oils. Im wondering what yall's thoughts are. I'm realizing it something i should more heavily consider doing to the pipes I make, as many of my customers would likely benefit from the simplicity of pre-carbonization. Whats the best way to do it? iv heard about mixtures of charcoal and buttermilk. Is that better than burning it? and once the mixture is applied, do you let it sit? or burn it? i have no clue. Can it be used to raise a chamber bottom drilled slightly too low for the air hole? Thanks.
Re: Precarbonizing a bowl
Do a search for bowl coatings. There is quite a bit of information in a handful of threads where we have discussed the pros/cons before.
BlueBriar wrote: Can it be used to raise a chamber bottom drilled slightly too low for the air hole? Thanks.
What scottie said for doing a search on the forum for formulas and methods of bowl coatings. No burning necessary.
As for fixing poorly drilled pipes, I wouldn't waste my time. If I mess up on the drilling, I toss the block aside and move to the next. If I were gifted a pipe by someone and it had poor drilling and I needed to fix it, I would use pipe mud, but never in something intended for sale. Pipe mud is made with water and cigar ash. Just a very small amount of water mixed into cigar ash packed into the bottom of the chamber will raise the bottom of the bowl up to where you need it.
BlueBriar
Post by BlueBriar »
Great thanks guys, ill go look through those threads again.
TIAFO
PremalChheda wrote:TIAFO
Can we get Alden in here to interpret?
TIAFO = This Isn't A Fucking Octopus!
What's that, you say? That's not right? HHmmmmm :lol:
Jthompson1995
Post by Jthompson1995 »
How about "try it and find out"
-Walter Blodget
I think it's
Tar Is A Faster Option
...as in road tar, bucket of.
Just slather it on like peanut butter. Done.
LatakiaLover wrote:I think it's
Are you making a sandwich? Never had a PB&RT....how are they?
andrew
Post by andrew »
Marvelous. They also can also be used as a fire starter.
andrew
Alden
Post by Alden »
Its Premals secret recipe for bowl coatings, he taught me when I was there;
Tabasco, Iodine, Avocado, Frogs and Orange Juice.
Mix well before use. And dont tell anyone what you use, just say its waterglass.
Alden
Post by Alden »
scotties22 wrote:TIAFO = This Isn't A Fucking Octopus!
This IS a Fucking Octopus !
socrates
Post by socrates »
All this time I thought brick mortar was the secret mixture. I guess that pipe is heading to the trash.
sakrin
Post by sakrin »
Similar question, but for the outside surface of the bowl. I have seen and done, torching the surface of the wood furniture before clear coating it. Apparently its a Japanese technique called Shou-sugi-ban or Yakasugi somenthing. Its a interesting finish, anybody tried that? I searched extensively but found no such pipes .
Europe's nastiest sock puppet, i even got teeth and claws LoL
Alden
Post by Alden »
It's been done. It can give a look similar to a sandblast, but I've never seen it look great.
sakrin
Post by sakrin »
For what its worth, and i suspect not much, it looks like this.
Experimented a litle, AND because the damn thing has cracks AGAIN, i baked it than i scrubed it with a steelbrush.
Maybe i will polish it just to see how it looks, colour looks nice.
To transmit some more expirience gained in this proces, firing the surface helps detecting cracks.
RDPowell
Post by RDPowell »
toe-inhibiting ankle-foot arthrosis? :nuts:
rdpipes.briar.club
