Small Dublin...
Small Dublin...
This pipe weighed in at a whole 17g and 5" long. Not sure I could safely make a lighter pipe.
I had planned on it being a good deal larger, but there was a weird place in the plateau that went in really deep. Not really a flaw, I guess, but made me remove a lot of material.
Alden
Re: Small Dublin...
Post by Alden »
I can dig it.
brooksbanister
Re: Small Dublin...
Post by brooksbanister »
That's a nice little smoke break pipe.
It's not the size that matters, but how you use it. :wink:
Good job.
-LB
Joe T
Re: Small Dublin...
Post by Joe T »
brooksbanister wrote:That's a nice little smoke break pipe.
Good job.
-LB
Ditto. Nice job. :thumbsup:
Joe Thieman
Albert.A
Re: Small Dublin...
Post by Albert.A »
I think it looks nice, but those walls must be mighty thin near the bottom of the bowl, right? :)
Good job!
/Albert
Perfection is key, but damn near impossible to achieve!
https://www.facebook.com/albertsmokingpipes
Re: Small Dublin...
Albert.A wrote:I think it looks nice, but those walls must be mighty thin near the bottom of the bowl, right? :)
Good job!
/Albert
I used a tapered chamber bit so the walls actually have about the same amount of thickness at the bottom as they do they top. It's a 3/4" chamber at the top and tapers down accordingly...though I wouldn't go any thinner, :wink:
Literaryworkshop
Re: Small Dublin...
Post by Literaryworkshop »
Nicely done, though I'd like to see some more pictures from other angles.
- Steve S.
Re: Small Dublin...
Literaryworkshop wrote:Nicely done, though I'd like to see some more pictures from other angles.
Re: Small Dublin...
"This pipe weighed in at a whole 17g and 5" long. Not sure I could safely make a lighter pipe.
Sure you could of. Saddle stem instead of taper may have reduced it by a gram. 16g's!
Re: Small Dublin...
A very nice pipe.
Re: Small Dublin...
Well played.
Re: Small Dublin...
I have hit 14 grams once with one of my "Scottie" pipes. The entire time I was working on it I was sure it was going to break it was so small. Normally they are between 16-18 grams. Bravo for making a regular pipe that light and being able to keep it looking good!
Re: Small Dublin...
I got down to 66 grams once and thought "Fuck it, I gotta stop before this thing disappears."
Re: Small Dublin...
You're supposed to take your monkey knuckles off the scale before you weigh your pipe, Sas...GEEZ!
Re: Small Dublin...
I like it!
