It looks like you're on the right track. Looks kinda like the bowl is a bit short and the stummel overall is a little chunky. One of the things I struggled with when I first started was knowing when to remove more material. This got easier the more I made billiards.The transition from shank to bowl is a little abrupt IMO. Some like that, some don't. I would have smoothed that transition out a little more. Looks like the inner and outer edges of your bowl's rim/chamber lost some stain- next time, try using less pressure when buffing. Sorry about the button. How did you manage to crack it? Over all, not a bad first attempt at the billiard. Keep it up!
Sasquatch wrote:And then if I shorten the shank, and then necessarily also shorten the stem, suddenly it's a billiard. Shank could be a hair thinner too I suppose.
This is the "smaller pipe" that Tyler mentioned on facebook. It's in there.
