I've noticed that some pipe makers do some shaping prior to drilling and some do the opposite. I'm wondering if there are pros/cons for going about it either way?
Curious, as always, to different methods of reaching the same end. Any and all thoughts on this subject, por favor... Personally, I currently drill without making any cuts, just squaring the block.
Drilling after shaping?
STD?
From what I have gathered the ShapeThenDrill method has the absolute advantage that if you should stumble across any flaws, sandpockets etc it is possible to "nudge" the shape a bit to evade those and then do your drilling. I have tried it once myself but (un-?)fortunately happened to get a "flawless" pipe in the first try so I didn't need to change anything , just drill and be happy
(The fact that I later decided to try rustication on the said pipe, had absolutely nothing to do with flaws, I just felt like it.)
- LexKY_Pipe
