Here is my first Lovat ( that I care to display ). It's also my first foray into sandblasting, which I think I'm going to enjoy. I was, again, overzealous with a file around the back of the bowl so I had to shape accordingly to achieve something close to symmetrical. I tried to turn the shank as closely to the final OD of the stem but left about 1/16" to sand down to. Ugh, next time I'll be turning the shank to the exact finished diameter of the stem, as I lose a lot of the straight lines I was hoping for. The stem is acrylic with a deer horn inlay and integral tenon. A couple questions for those who wish to critique:
1: How much of your shaping process is 'at the wheel'. I currently do all my rough shaping with 36 grit then 100 grit then go to files bring everything together. Then I move to hand sanding. Seems like I could do a little more on the wheel but with finer grits.
2: The stem. I had drilled the draught hole using a 5/64 tapered bit then finished it the rest of the way through with a 1/16". When creating the 'funnel' from the button back to the tapered end of the draught hole, I end up with a jagged 'rectangular' portion for the funnel where it meets the round portion of the tapered bit. Am I missing something here? Should be a seamless transition, right?
3: How do you approach the stem/shank junction? I've been doing it very carefully with electrical tape, files and then sandpaper but when holding it to the light, it always seems a little lumpy for some reason.
Thanks for your critiques, they're helpful.
Mark
