Hi guys!
Since I have no band saw at home (yet! hehehe), I've been thinking of making the first rough shaping with a cop saw, before the files/Dremel. Does it do the job? What kind of saw you suggest?
Rough shaping by hand
- omar_colocci
Omar Colocci
Omar Colocci
I use a coping saw and a hacksaw. I typically prefer the hacksaw as the blade does not flex as much as the coping saw, and it is easier to cut a straight line through the briar without as much wandering.
A couple of points. This is not nearly as accurate as using a band saw, and I leave plenty of room for error. Naturally, I have to sand and file a lot more than if I had a band saw, but it works.
If you are going to be sawing by hand you might consider Japanese saws.
http://www.leevalley.com/wood/page.asp? ... ncy=1&SID=
They are not exactly cheap but I think they would be better than a hack saw.
John
www.crosbypipes.com
www.crosbypipes.com
Actually, the frame on the hacksaw I've got is much more rigid than the cheap hacksaws, and with a reasonably fresh blade, it goes through briar pretty well. Your point is well taken, though, there are probably better options if one is hand sawing briar.
If I ever sell a couple of pipes, a bandsaw is high on my list of things to acquire.
- omar_colocci
I have a hacksaw and I also have a great backsaw. I must admit I handle the backsaw better, maybe because the frame of my hacksaw is too old and not working anymore and I should get a new one, but I simply can't get cuts straight.
All hacksaws I've dealt with were VERY strong and I really have never seen ANY kind of wood affecting the frame or the blade, since I've sawed Brazilian Macaranduba, that one of the hardest woods in the country and it only took longer (waaaaaaay longer
Well, that's it. My kit and stains have arrived at the house of my wife's friend and she will ship it to Brazil soon I hope. May I still have the time for a second order.
Omar Colocci
Omar Colocci
