Up yours.Ocyd wrote:You people and your balls. Take them out of the chamber if you're going to shoot the top view. May as well as be covering your pipes in hello kitty stickers for all the effort you're putting into getting such detailed hi res pictures.
Then you probably shouldn't use it. You're selling to pipe smokers, not normal human beings.Solomon_pipes wrote:Well rad, i smokex her super hot and I bit the HELL out of that stem. Clenched until my teeth hurt. I finally felt it collapse and when I took a look the button had cracked on the top and partially up the stem. I am fairly certain this stem material is safe for normal human beings.
