There is no shellac coat because I still needed to order flakes, but I couldn't resist giving it a go. Please critique my sanding job and staining. I feel I removed too much color when sanding back through higher grits. Would sealing the under-stain with shellac help this? I was unsure if you guys are doing a shellac seal coat between the different colors or doing the undercoat using alcohol and the top stain as oil of water base and then shellacking.
My test method based on what I currently have available to me...
Quilted Maple
side 1:
150
180
220
320, stain perfect brown
400, stain perfect brown
600, stain perfect brown
800, stain blue
1200
3600 up to 12000 using 3m pads and white diamond buff in between finishing off with carnauba wax
side 2:
same as above, but just reverse the stain colors through all steps.
No shellac as of yet; waiting on my order to come in.
side 1: perfect brown under stain, blue top stain.
side 2: blue under stain, perfect brown top stain.
