Ok, so I've tried myself in rustication for the first time. I used Dremel bits 191 & 192. Also, I noticed that it is quite hard to put the carnauba on such surfaces. Do you have a trick for it?
Before:
Almost done:
After:
Rustication
Rustication
No shellac, just tripoli and carnauba. As you say... I'm thinking of shellac not being a bad idea at all!
After carnuba, have you tried a heat gun to help the wax flow into the surfaces - then perhaps a clean buff.
Kim Kendall
http://www.PenguinBriar.com/
Nope, but that very suggestion has been made a few minutes ago on another forum, so I guess I better believe that No, for real, that makes sense...kkendall wrote:After carnuba, have you tried a heat gun to help the wax flow into the surfaces - then perhaps a clean buff.
I'd like to see that! Sounds interesting...Tsunami wrote:I really like the way that came out. Well Done! I have been experimenting with a hammered rustification like a hammered bronse.
- ToddJohnson
