Oak Billiard Updated
Wallaby
Post by Wallaby »
I made the changes that Sasquatch suggested. I think it's a much better pipe. This forum ROCKS!!!
I removed material at the front of the bowl and I removed the taper on the shank. Now the shank is only .002 from end to end.
Thanks for your help Sasquatch.
Wallaby
mathias65
Re: Oak Billiard Updated
Post by mathias65 »
much nicer .. and i dig the pipe smoking big foot in the pic too. :)
mathias65 wrote:much nicer .. and i dig the pipe smoking big foot in the pic too. :)
Agreed.
Post by Tyler »
That's better. Now make the top of the bowl cant forward, instead of sloping it back so it is parallel with the shank. It looks like you drilled it with a proper cant, then didn't follow through with the rim. The rim should be perpendicular to the axis of the chamber on all 360 degrees.
Wallaby
Post by Wallaby »
Tyler wrote:That's better. Now make the top of the bowl cant forward, instead of sloping it back so it is parallel with the shank. It looks like you drilled it with a proper cant, then didn't follow through with the rim. The rim should be perpendicular to the axis of the chamber on all 360 degrees.
Good info. I did not know the rim was supposed to be canted.
Thank you Tyler. I will add this info to my note book. So much to learn....you guys sure know your pipes.
I agree. Much, much better shaping.
